A problem has been detected which is interfering with the normal operation of the system. The system is not functioning as expected. The problem may be related to the failure to allocate an internal system resource on the card.
The exact remedy is dependent on the particular situation; but the problem may be resolved by retrying the operation when the resource becomes available.
Error
adj %ipAddr%: %msg%
| Name | Type |
| ipAddr | IP |
| msg | Printf |
